check engine light flashes
so i was looking threw the diy sticky on the forum and i found this
I wanted to post this as a sticky to help all the new owners of newer 1st gens. ON-BOARD DIAGNOSTICS Dodge OBD1 Pre 96 1. Cycle the ignition key ON-OFF-ON-OFF-ON within 5 seconds. To cycle the ignition key ON means to turn it only as far as it takes to get the radio to come on. It does not mean to turn the engine on. 2. Count the number of times the "check engine" lamp on the instrument panel flashes on and off. The number of flashes represents the code. There is a slight pause between the flashes representing the first and second digits of the code. Longer pauses separate individual codes. For example, flash-flash-flash [pause] flash-flash represents the code 32. A code of "55" represents end of error codes. If this is all you get then no error codes are stored in the computer. This is the normal condition CODE Description of Trouble Code 11 Timing belt skipped 1 tooth or more from initial learned value, Intermittent loss of either camshaft or crankshaft position sensor, No crank reference signal detected during engine cranking 12 Direct battery input to PCM was disconnected within the last 50 key-on cycles (normal) 13 No change in MAP from start to run 14 MAP sensor voltage too low 15 No vehicle speed sensor signal 17 Closed loop temp not reached or engine cold too long 21 02s sensor problem (oxygen sensor), upstream or down stream 22 Engine coolant temp sensor out of range 23 Intake air temp sensor out of range 24 Throttle Position sensor out of range 25 Idle air control motor circuits, target idle not reached (+/- 200),vacuum leak found 27 Injector control circuit 31 Evap purge flow monitor failure or evap solenoid circuit 32 EGR system failure 33 A/C clutch relay circuit 34 Speed control Solenoid circuits 35 Rad Fan control relay circuit 37 Torque converter clutch solenoid CKT or park/neutral switch failure 41 Generator field not switching properly 42 Fuel pump relay control ckt, Auto shutdown relay control ckt, No ASD relay output voltage at PCM, Fuel level sending unit volts out of range, Fuel level unit No change over miles 43 Multiple/ single cylinder misfire 44 Battery temp sensor volts out of range 45 Overdrive solenoid shorted or open (automatic transmission only) 46 Charging system voltage too high 47 Charging system voltage too low 51 Fuel system lean 52 Fuel system rich 53 Internal control failure 54 No Cam signal at PCM 55 End of error messages (If you get this only, no errors were found) 62 PCM failure SRI mile not stored 63 PCM Failure EEPROM write denied 64 Catalytic Converter Efficiency Failure 65 Power steering switch failure so i went to my truck and tried it and i got flash flash flash pause flash flash flash flash pause flash flash flash flash flash flash flash flash flash pause flash flash flash flash flash flash flash and then no more flashes so would that be code 23 air intake sensor out of range ?/ my engine has been running a little rough at idle and in gear and has random like miss fires wile overdrive is off and the rpm above 1700 rpm but i have looked past this but since iv seen this im thinking this might be the problem or that my computer is just flashing those lights to confuse me thanks, cam |
Sometimes the flashes can be deceiving. There is no code 97. My truck flashes for about 5 minutes total. Its depressing, so I just sort of gave up, and decided to live with my problem flasher.
Your computer obviously has taken a great dislike to you and is therefore on a mission to confuse you. LAUGHING MY ARSE OFF
Run the code interrogator again. Do you have a manual and does it contain the specs for the intake sensor? |
