Is my torque converter bad
Bought an 85 d150 shortbed yesterday and when i was almost home it all of a sudden quit driving and started revving up when i hit the gas in all gears i had it towed home and i got it to go backwards then i hit the brakes and i had the same problem as earlier after about an hour it went forward and i had yet again the same problem and now if its not in park it has a squealing noise from right behind the motor and when i would go the tires would spin the stop and then i would go and on the way home going up hills it would like loose power even if i hit the accelerator
Not sure if this would help but have you checked the trans fluid
Yes i checked it and it was low i added a gallon and it now is reading way high but i only worked with it about an hour yesterday oh and its an automatic
If not mistaken check it in N
I did i think it just needed to drain still my dad and i were working on it and he added the fluid while it was running
might seem like a waste of fluid now but did you pull off the pan to the tranny and check the filter to see of its clogged?
Originally Posted by grantshultz1994
(Post 3125293)
