87 D150 Ignition Switch Install
Installing a new Ignition Switch.
How do you go about adjusting the switch so the actuator rod is in the right place? The new switch came with a little plastic pin that locks the slide in place. What position should the key be in to mount the switch in the right position? |
cliff notes version from my manual. Disconnect the negative cable. 2:Turn key to accessory. 3:Remove steering column cover. 4:Unplug connector and remove bolts, detach switch from actuator rod. 5.With the switch in lock position engage it to actuator rod, push up to remove any slack from the rod before tightening bolts.
