VIN# only shows 13 characters
I have a 1974 Dodge D10 2 wheel drive short bed w a 318 and I'm trying to identify if the truck was changed at some point or is still as it was manufactured. The truck was given to me as a gift but I don't have any paper work or registration that I could refer to please help.
Prior to 1981 there was no set or regulated format for VIN numbers so different manufacturers used different systems, and the numbers varied between 11 and 17 characters. Your VIN is therefore not unusual. There's plenty of sites online dedicated to decoding VIN numbers (even the pre-81's), so a quick google search should find you what you need. But these two should at least get you started.
This one lets you enter your VIN and decodes it for you
http://www.t137.com/registry/help/decode.php
This one has you go through digit by digit and decode it yourself
http://oldmopar.com/72-79DodgeTrucks/Info.html
Good luck!
Good luck!
What's your VIN? I hadn't tried 13 number VIN, but with usual ones it works fine. https://vinnumber.net/makes/dodge/
Trending Topics
