1991 A518 w/ OD and Lockup
I have a 91 B350 and am not finding the info I need elsewhere so I thought id try here.
It has the A518, with overdrive and lock up. I don't believe its locking up.
I think I should hear if not feel the lock up in the 3rd gear range before it shifts into OD, but I only hear and feel 3 actions.
If its not going into lock up. where should I begin looking for the cause?
thanks for any help or advice in advance
Somewhere there was a post, but I cant find it now, where someone explained how to tell from the wiring under the vehicle if I have a lockup converter or not.
Can someone chime in? I know there is a neutral safety switch, but there is another harness near the rear of the housing. I think its a 3 wire, or 4 wire depending lock up or not,
Can someone confirm?
Lockup
Near the rear of transmision there is a 3 wire plug. the center wire is your hot wire. When od engages it first grounds the wire closer to the rear. Then it grounds the wire closer to the fromy to lockup converter. od will not work if speedometer doesn't send signal. I hope this helps
