Engine backfiring and stalling after warming up
I have a 89' D150, 318 TBI. When I start the truck it runs perfect. after driving it around for 5 or ten mins it starts to stutter and struggle for power, then it will back fire and die. After that it will not start up again but if I come back the next day it starts again and repeats the process. Has a new fuel pump, fuel filter, spark plugs and air filter. I think its a fuel/air issue (maybe ignition), but im not too sure. I am pulling 1 code from the OBD1 and its for torque converter clutch solenoid(37). I dont think that would cause this problem, or could it? if not, what else should I do? Im not super mechanically inclined, learning as I go. thanks.
Run it till it quits. Pull the cover off the air filter housing, see if the injectors are actually spraying fuel while cranking. (requires a second person.....) If that looks good, verify you are getting spark to the cylinders. (I just pull a plug wire, put a spare spark plug in it, ground it would somewhere, and crank the engine. See if it fires.)
once you know what's missing, you can find out why.
You seem to be pretty knowledgeable, is the fuel pressure regulator by the injectors? im learning all of this, sorry if it is a dumb question. I have not gotten a chance to look yet, I just want to have a general idea where to look.
