1989 D100 intermittently stalls and idles poorly..
1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
the noise is coming from front area but with a little throttle goes away also just replaced the map sensor and coolant sensor as well and it was okay for moment then did same exact thing so im really stuck now
hello guys so my truck seems idle lower now about 2800-3200 roughly idles nicely drop into gear goes about 2200-2400 and when i give it gas and hit throttle good it sputters then backfires and dies and puffs out the intake so what would cause this...fuel pump maybe? idk replaced about anything could think of.. also noticed drivetrain seemed to move more than i think it should be but could be wrong idk why would die like that and even when go drive forward itll bog down and stall unless gas it any thoughts??? anyone please love this truck and just wanna get running nice and smooth..
do you have any ideas where ive replaced all hoses i could see so far idk if maybe someone mixed some up somewhere or what dont have diagram or anything so idk but yeah seems like it has leak but i cannot find one at all its got me stumped...
I have a Haynes repair manual but I’m not sure if would have one in it but my brother in law been helping me try find problem and said sounded like was sucking a lot of air but I literally replaced all vacuum lines I could physically see but someone else has messed with before so idk if could have got mixed up or whatever I’m not real sure
