318 carb
Besides having emission ports for the charcoal canister, and different choke setup (electric, Thermo static, cable) not much. There may have been different Jets installed for emissions. I put an 86 d250 2 barrel on a 68 Plymouth fury. I just plugged the emission ports, ran just fine. Ran so good it idled without the idle screw lol. As long as they are both 2 barrels, and Holly I don't see why it wouldn't work. If you have emission laws you'll just have compare each carb and hook up your emissions if they look under the hood.
Is this the carb. you are looking at? https://www.ebay.com/itm/Carburetor-...hQJ~:rk:3:pf:0
If so, I suspect the reason they are so cheap is, they are chinese knock offs.
Have no idea how it would perform or hold up.
yes, but it's received a few good reviews. but i was also looking at these https://www.ebay.com/itm/1984-Chrysl...d7e:rk:25:pf:0 thanks
