1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I just bought a w150 with a 360 in it for 200 dollers but the transmission went out... and idk what tranny’s went with that motor and year... it is a automatic
best to run the vin and get a build sheet unless the sticker is still on the hood. you use to be able to get them online but it looks like dodge has changed their website so you can't but you should still be able to call a dealer or email dodge to get it.between 88-93 there was so many changes it is hard to tell which trans it might have. i think there is 4 different auto transmissions available in that time period.
I think there was only two for 360, the overdrive A500 was an option. If you have the overdrive switch on the dash then that's what you have. Other wise it's 727.
A500 is my best guess, given the year. You could rebuild what you have, might be hard to come up with a good A500 in the jyard - and having someone rebuild one for you will likely make you want to junk the truck
Here is a video, I'm sure there are others out there...
