1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
I have a 1984 Pickup, 318, new alternator, new voltage regulator, new brain box, wont charge. Alternator is new and has been retested, when both field wires are attached alternator starts squealing but wont charge. Any help would be appreciated. Thanks
Testing alternator only shows battery voltage, its brand new and has been retested twice to ensure that it works.Voltage gauge doesnt even show a discharge or charge when vehicle is running
If you are only seeing battery voltage at the alternator, with the engine running, the alternator is not working. If the alternator works fine on someones test stand, then the regulator, or wiring becomes the next suspects.
it really sounds like a bad alternator if it the belts squeals when you hook up the field wires but no voltage comes out . i would agree with heyyou to check wiring and maybe try changing the voltage regulator, new one are more prone to being junk and failing
