1st Gen Ram Tech'93 & older Rams: This section is for TECHNICAL discussions only, that involve 1993 Rams and older. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
New here. Just bought a 1988 Ram stock. Looking to replace the motor. What's the most power I can put in there without having to completely change everything?
You would need to replace the trans then as well. If it's carbed, electrical will probably be about the same, perhaps just a bit further away for some things. If it is fuel injected, that would be a major change......
