Distributor issues- 1990 W150
Old 01-02-2020, 01:53 PM
Cwilliams4303's Avatar
Cwilliams4303
Cwilliams4303 is offline
New Member
Default Distributor replaced, needs tuned after?- 1990 W150
just Replaced the distributor on my truck
Got the truck running but need to tune it before I can drive it? When I started it up is idled for about five minutes but every 15-20 seconds the engine sounds like it is revving at the end of the rev it will sputter for about 5 seconds. Can’t find anything on it online. Maybe I didn’t search the right thing. Looking for ideas
Is fuel injected
Old 01-02-2020, 09:25 PM
rebeltaz83's Avatar
rebeltaz83
rebeltaz83 is offline
Turn the distributor as you try to crank it, gonna take 2 people. Sounds like it's advanced a little too far. Or turn it a little at a time until it starts either direction. If it wont start one direction go back to the other way.
Old 01-02-2020, 10:02 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
is the engine turning but won't fire up or is it not turning?
Old 01-03-2020, 06:34 AM
Moparite's Avatar
Moparite
Moparite is offline
Also you can put it in 180* out, Did you pay attention where it was before removing it?
Old 01-03-2020, 11:59 AM
ol' grouch's Avatar
ol' grouch
ol' grouch is offline
Originally Posted by Cwilliams4303
just Replaced the distributor on my truck and now it won’t start, double checked that it is plugged in tightly. The battery in the truck is charged but the engine just can’t seem to turn over. What should I look at trying?
You didn't get it on the exhaust rather than compression stroke did you? Pull the plugs and use a wooden dowel rod to find when the #1 piston is at the top of the stroke. When it's TDC, check your rotor. If it isn't spot on, move it until it is. Replace everything and try to start it up. If it starts, great. Time it and go on. If it doesn't, pull the distributor and rotate it 180 degrees. I'll bet it starts then.
Old 01-03-2020, 01:01 PM
crazzywolfie
the engine will still run even with the distributor 180* off. you usually just get a lot more fuel being blown out of the throttle body while doing so.
Old 01-03-2020, 02:20 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,385 Likes on 3,125 Posts
If fuel sync is 180 off, the engine may still run, but, if timing is 180 off, it will backfire, and make all sorts of rude noises. You are firing the plugs with valves open.
Old 01-03-2020, 02:29 PM
crazzywolfie
believe it or not it runs better than you would think 180* off other than fuel coming out the throttle body. i found this out when i had the distributor out of my 91 and someone spun the engine over while i was getting parts.
Old 01-03-2020, 06:48 PM
Cwilliams4303
New Member
the engine will turn but won’t fire
Old 01-04-2020, 08:27 AM
ol' grouch's Avatar
ol' grouch
Start tracing wires. Once you're sure the plug wires are at the right location and the distributor is right, you probably have a wire unhooked somewhere. I helped work on a car once where it had been converted and wouldn't start. I had the owner try to start it while I jiggled wires. I had checked everything with a volt/ohm meter and test light. It turned out to be a bad connection on the power side of the ballast resistor. The resistor was good, the connector was loose. When I'd press a test lead on it, it made contact. Less than 5 minutes and a new plug and it was going. I'm not saying that's what you have, but it may be something simple like that.
Quick Reply: Distributor issues- 1990 W150
