Bluetooth kit?
06-08-2014, 02:23 PM
on
Bluetooth kit?
Just picked up a 2013 Avenger the other day, and was only a little disappointed to realize bluetooth wasnt built in
Any recommendations for a good (and stealthy) bluetooth kit?
06-10-2014, 04:48 PM
on
159 views and 0 responses.
I see.
06-10-2014, 09:23 PM
What radio is in the car? If it is the stock radio, you should be able to have the uconnect module installed for the seamless look. It is a little more expensive than buying a $50 fm transmitter type, but it is nice.
06-26-2014, 02:51 PM
on
If it's an 2013 model then the only ones that have Bluetooth available standard are the ones with a 730N/RHR unit in them. 2014 Avengers have Bluetooth with every uconnect but the 130/RES unit. you can check out
http://www.driveuconnect.com/system/dodge/ but like KRZY.BMET said you should be able to have the module installed as long as its a 130S/RES or better and not a 130/RES.
06-27-2014, 11:32 PM
If you got the base low line radio, for the price of a Mopar U-Connect kit, you probably rather just go buy an aftermarket Radio with built in blue tooth + a lot more other feature.
