2008 - Current Dodge Avenger The new Dodge Avenger gives a sporty look to the often drab mid-sized sedan class, with the possible future option of AWD and a performance engine upgrade.
Key doesn't turn
Old Feb 4, 2016 | 02:31 PM
Doomtionary's Avatar
Doomtionary
Default Key doesn't turn
Hello everyone. I'm having an issue with my 2008 Avenger where in the mornings when it's below freezing (usually below 30 F) and I try to start my car but the key in the ignition will not turn. I can use the remote start and the ignition will start but as soon as I put the key into the ignition the engine shuts off. I have tried my spare set of keys as well and the same thing happens to them so I don't think it's because the key has gone bad. If I leave the car sitting for awhile and come back when it is warmer the key will turn. Any suggestions before I take it to the dealership?
Thank you.
Old Feb 5, 2016 | 08:48 AM
DodgeCares's Avatar
DodgeCares
What type of engine do you have, Doomtionary? I can search for a potential TSB that could be related to what you're experiencing.
Old Feb 14, 2016 | 01:39 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Your key cylinder is seizing up from the aged lubricant they use to build them. What you can do is get a dummy key cut (all metal) and tap the end of it with a hammer and it will turn. Don't strike your fob key or you'll kill it. At least it will save you a tow bill anyway. They're easy to replace. Probably get charged an hour labor plus parts and a small charge to code the new cylinder.
