ABS and brake light on
Hi, I have a 99 Dakota 5.2 Sport 2wd with all factory heavy duty packages and about 64k on the clock. Currently theabs and brake lights are illuminating on the dash. The brakes feel fine, there is plenty of travel, pad and shoesand overall the truck runs fine. I searched a little bit and found others with similar problems, only their speedo wasn't working either. My speedo is working fine. It seems like a common problem. Have there been any factory recalls for this sort of issue? From what I have found while searching it seems that there is a rear speed sensor that would most likely need replacement. Am I missing anything here? TIA
