bad gas mileage!
Old 01-23-2008, 12:47 PM
snookftbl26's Avatar
snookftbl26
snookftbl26 is offline
Default bad gas mileage!
i have a 1999 Dakota SLT 5.9 318. i am getting about 11 mpg in town and about 12.5 highway. I dont drive it hard i tend to go the speed limit to get better gas. i am looking for ways to get me better gas. i have 265/75r/16 tires. i am wondering if K&N Air Filters would get me a little better mileage, and also a super chip programmer set to economic setting. I am also up for anything that would help me get better gas mileage.
Old 01-23-2008, 01:20 PM
Nicegy525's Avatar
Nicegy525
Nicegy525 is offline
Default RE: bad gas mileage!
is it a 5.9L or a 318? the 318 is the 5.2L motor 11 city sounds normal. do you have a brush guard or bug shield that would cause drag at highway speeds? Is the truck lifted? these things will lower your highway gas mileage.
Also what kind of gas are you running? for the extra 2.00 bucks a tank, the middle grade gasoline will give you a bit of an increase.
when is the last time you gave a it a tune up?
plugs,
wires
cap & rotor
Air filter (K&N will help)
Fuel filter (often most overlooked tune up item)
and a bottle of fuel injector cleaner.
These are the basics of proper maintainence and will give you good gas mileage without spending gobs of money for that extra 2mpg's
Old 01-23-2008, 01:51 PM
4x4kota's Avatar
4x4kota
4x4kota is offline
ORIGINAL: Nicegy525
plugs,
wires
cap & rotor
^+1! Also if none of those things make a difference, you might want to consider 02 sensors
Old 01-23-2008, 02:29 PM
scandal669's Avatar
scandal669
scandal669 is offline
little things add up...air pressure in the tires, make sure it is tuned up, air filter is clean, exhaust is good, keep the oil changed...
i have also read that 87 octane gas is best and all that is required for these engines. the higher octane gas runs hotter and burns faster, thus using more gas.
Old 01-23-2008, 05:04 PM
SmokedRail07's Avatar
SmokedRail07
SmokedRail07 is offline
A high flow air filter and exhaust would help some. I would not buy a chip becuase for the little bit it will help you out and the cost of the chip it is not worth it.
Old 01-23-2008, 06:11 PM
99dakota318's Avatar
99dakota318
99dakota318 is offline
I put a lighter oil in my truck. It was 10w-30 now I have amsoil 5w-30 and getting an extra 4 mpg!!!! plus its better for me to have a lighter oil since I live in cold MI.
Old 01-23-2008, 11:15 PM
geoffb123's Avatar
geoffb123
geoffb123 is offline
How do you change the fuel filter? Isn't that inside the gas tank????
Old 01-23-2008, 11:42 PM
moe7404's Avatar
moe7404
moe7404 is offline
moe in wichita ks
most people dont know it but higher octane gas burns slower. not hoter
Old 01-24-2008, 12:59 AM
geoffb123's Avatar
geoffb123
Just look in the manual. If the manual is telling you to use 87 octane, then use 87 octane. I tryed using premium (91 octane) in the dakota. Couldn't even tell the difference. The only thing I do is just go to canadian tire and buy some injector cleaner. That made a noticeable difference in performance and mileage. Why spend the extra 2$ at a tank if it really does nothing. Only time i'd fill with premium is if I was driving a higher end vehicle and it asks for it.
Old 01-24-2008, 07:37 AM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
ORIGINAL: geoffb123
+1 the only vehicle we have ever put premium in is my moms BMW the dodge dealer actually told us not to put anything but regular in this truck YAY!!!!
Quick Reply: bad gas mileage!
