Manifold replacement cost?
I discovered two manifold(driver side)bolts with the heads broken. I dont have the time or all the means to replace this manifold. Anyone have a ball park price range if I take it somewhere and have it replaced?
'98 dodge dakota 4X4 V6 3.9L Extended Cab |
RE: Manifold replacement cost?
Its just a matter of using an ez out to remove the broken studs then installing new ones. 1 hour labor, 2 hour max if they are stubborn plus bolts so maybe $75.00 to $150.00 depending on the labor charge.
