won't fire
Any suggestions daughter has a 2001 Dodge Dakota 4.7 litre truck
It has been at the garage for a week now.. Daughter was driving and it quit on her.. Towed it back to town Mechanic checked out and thought for sure it was PCM module (ouch) replaced it and it still will not fire He said he checked crank shaft sensor and timing chain NOTHING I am not sure but he said he was on the phone all day with Tech Support and no suggestions ANYONE HAVE ANY HELP Thanks in advance |
RE: won't fire
Not sure whats on the 4.7's I would guess a simple fuse, something is not getting power. Hook it up to computer it will usually tell you rather than guessing...
I believe the 4.7 has a coil for each cyl, so thats out of the ?, so something before the ecu... wire or fuse or relay. |
RE: won't fire
We're assuming that its a competent shop that checked for spark, air and fuel first right?
RE: won't fire
When that happened to our Ford truck, it ended up being a fusible link supplying the computer circuit. Did not show up on our diagnostics test. Pain to find
RE: won't fire
I got in my 97 5.2 dakota one morning and it turned over but didnt start. so i checked for spark and it was weak orange and was flooded bad. wouldnt even start off starting fluid. i had to pull the distributor cap off and clean the contacts they were all corroded put it back together dried the plugs and it fired right up.
| All times are GMT -4. The time now is 06:32 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
