DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Dakota Tech (https://dodgeforum.com/forum/2nd-gen-dakota-tech-67/)
-   -   mystery CEL's..... (https://dodgeforum.com/forum/2nd-gen-dakota-tech/196651-mystery-cels.html)
rtdakota2001 Apr 9, 2009 01:31 PM
mystery CEL's.....
after i did my long tubes i have 2 CEL's, ok no biggie i'll go look them up here on DF........... THEY ARE NOT ON THE LIST! p0031 and p0051. they are not on the list of CEL's in the sticky here on DF. ok, now what?
95_318SLT Apr 9, 2009 01:37 PM
These codes are not chrysler specific codes, they are general emissions codes... which is why they don't show up on the chrysler code list, this is copied from http://www.obd-codes.com/trouble_codes/P0010-P0099
Fuel and Air Metering and Auxiliary Emission Controls
  • P0010 "A" Camshaft Position Actuator Circuit (Bank 1)
  • P0011 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1)
  • P0012 "A" Camshaft Position - Timing Over-Retarded (Bank 1)
  • P0013 "B" Camshaft Position - Actuator Circuit (Bank 1)
  • P0014 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 1) - See Trouble Code P0011
  • P0015 "B" Camshaft Position -Timing Over-Retarded (Bank 1) - See Trouble Code P0012
  • P0020 "A" Camshaft Position Actuator Circuit (Bank 2)
  • P0021 "A" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2)
  • P0022 "A" Camshaft Position - Timing Over-Retarded (Bank 2)
  • P0023 "B" Camshaft Position - Actuator Circuit (Bank 2) - See Trouble Code P0020
  • P0024 "B" Camshaft Position - Timing Over-Advanced or System Performance (Bank 2) - See Trouble Code P0021
  • P0025 "B" Camshaft Position - Timing Over-Retarded (Bank 2) - See Trouble Code P0022
  • P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
  • P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
  • P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
  • P0033 Turbo Charger Bypass Valve Control Circuit
  • P0034 Turbo Charger Bypass Valve Control Circuit Low
  • P0035 Turbo Charger Bypass Valve Control Circuit High
  • P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
  • P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
  • P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
  • P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
  • P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
  • P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
  • P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
  • P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
  • P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
  • P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
  • P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
  • P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
  • P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
  • P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
  • P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
  • P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
  • P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
  • P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
  • P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
  • P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
  • P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
  • P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
  • P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
  • P0065 Air Assisted Injector Control Range/Performance
  • P0066 Air Assisted Injector Control Circuit or Circuit Low
  • P0067 Air Assisted Injector Control Circuit High
  • P0070 Ambient Air Temperature Sensor Circuit
  • P0071 Ambient Air Temperature Sensor Range/Performance
  • P0072 Ambient Air Temperature Sensor Circuit Low Input
  • P0073 Ambient Air Temperature Sensor Circuit High Input
  • P0074 Ambient Air Temperature Sensor Circuit Intermittent
  • P0075 Intake Valve Control Solenoid Circuit (Bank 1)
  • P0076 Intake Valve Control Solenoid Circuit Low (Bank 1)
  • P0077 Intake Valve Control Solenoid Circuit High (Bank 1)
  • P0078 Exhaust Valve Control Solenoid Circuit (Bank 1)
  • P0079 Exhaust Valve Control Solenoid Circuit Low (Bank 1)
  • P0080 Exhaust Valve Control Solenoid Circuit High (Bank 1)
  • P0081 Intake valve Control Solenoid Circuit (Bank 2)
  • P0082 Intake Valve Control Solenoid Circuit Low (Bank 2)
  • P0083 Intake Valve Control Solenoid Circuit High (Bank 2)
  • P0084 Exhaust Valve Control Solenoid Circuit (Bank 2)
  • P0085 Exhaust Valve Control Solenoid Circuit Low (Bank 2)
  • P0086 Exhaust Valve Control Solenoid Circuit High (Bank 2)
© 2026 MH Sub I, LLC dba Internet Brands
