Headlight lens removal?
Hey guys, just wondering how to remove the headlight housing, or just the clear lens if possible? Im trying to get it off to sand and shoot with a clear cause its yellow and gross. I know its held on by three screws, but where?:
I found the bottom two bolts and got them out, but the hell am i supposed to the top left one out? this is drivers side btw
If you remove the turn signal housing first, it will give you access to the other bolts. There is a small T10 or T15 torx bolt in the turn signal housing and then pull it straight out and swing it to the side.
