Wheels
ok the tire size is 32 11.5 15 but the rub. will 31 10.5 fit so they wont rub? and are there different width's of wheels?
really dude? first search the forum, then look at the sticky's section. Im beginning to think people who ask " what size tire" questions are just trolls. someone has to make a filter that bans posts with the words: what, largest, tire, size, and rub.:icon_deadhorse:
lol ya that sounds like an idea. Its right in the FAQ section, just go read it...
Originally Posted by thunder98110
(Post 1904792)
To everyone asking these questions, try this... cause its what I did and worked just fine: Pick the size tires you want to run and build your truck to fit them!! |
**Please delete... double post**
yea well guess what that didn't help me at all. it has a 3" lift but i think the tires are to wide. will a inch or two inches smaller fit so it doesn't rub at all?
If you have a 3" lift you shouldn't be having rubbing issues.
if you are using aftermarket wheels then you need to look at a wider off-set. The tire isn't the issue, the off-set is. If you are using OEM wheels then yes they are too wide because you need a wider off-set wheel. |
yea but i dont want to change all that stuff i just want to see if i would be able to go down a size without changing the wheels and everything.
Yeah go down a size
