i have stock wheels and tires on my 2000 dakota. (275 60 15) ...and im looking to get new snow tires. i found some, 235 75 15.
Without going into detail about the measuring system, I'll just tell you that the 275 60 15 is a 28 inch diameter tire and 10.83 inches wide. The 235 75 15 is a 28.88 inch diameter tire and 9.25 inches wide. As long as you haven't lowered your truck, and have factory size wheels, it will fit. Just be aware that the new tire is much narrower and a little taller.
So what actually is the stock size tire for a 2nd gen Dakota? The tires that came on mine say 32x11.5x15. Stock 15" rims obviously, but is 32" larger than stock? Was this size an option or is this something aftermarket that was done by the last owner?
yea the tag on my door frame is way wrong, it says all the bone stock stuff, my truck came with 255/65 tires on the 16x8 rims which was a option wouldn't decoding the vin tell you exactly what you have as far as options?
yea, you can get a build sheet that shows how your truck was put together pretty much, shows tires size, alternator output, everything you'd want to know
