diff fluid weight
how much did u end up spending on the oil i was looking at summit and the royal purple stuff was $18 a quart!!! that stuff is expensive, i want to do mine just dont really feel like spending that much, and did u have to do an additive the haynes manual says there is some additive if u use the mopar stuff
Some do, some don't, depends on the axle it came with. All Dakotas come from the factory with 75W90, GL5 gear lube in the differential. The limited slip use a friction modifier additive. Mine has the corporate "8" open differential and I'm sure it took a little over 1 quart to fill when I put Mobil 1 synthetic in it. 8" fills to 1/4" below the plug and 9" fills to 3/8" below the plug and there is no gasket. Use RTV.
so it only took u 1qt to fill it after draining? i thought it was supposed to hold like 4qts or something i think thats what my haynes manual says
