Towing a 4WD truck possible?
I am guessing this is not possible, but can you safely tow a 4WD truck with all four wheels on the ground using a tow bar? I know it would be ok for a short distance at lower speeds to get yourself somewhere safe, but what about long distance on the highway? I want to say it wasn't possible because of the transfer case, unless of course you disconnected the driveshafts.
I should add this to the post.
http://www.motorhomemagazine.com/Ima...ngs_p20_28.pdf
It shows the 2006 Dakota being able to be flat towed. From what I understand you need to put the transmission in park and the transfer case in neautral, then the axles are free to spin but the transmission does not. Does this sound right?
