Strange un-even brake pad wear
Took my front wheels off the other day to do a quick rotor swap and noticed that on both sides there was a significant difference in the wear on the brake pads. The inside pad (against the caliper) was about 80% worn while the outside one was practically brand new. Both sides had this problem, and the pads only have about 5k miles on them.
Any ideas as to whats causing this? The truck seems to stop fine, I even locked the front brakes up on dry pavement the other day.
When you replaced the pads did you lube the slide pins? The caliper in a sense floats on these pins. They allow the outside portion of the caliper to clamp down on the rotor with the same force as the inner portion where the pistons are located. They also help to account for brake wear.
If the pins are corroded and seized that would cause the problem you describe.
With the truck jacked up and the wheel removed and brakes cool you should be able to grab ahold of the caliper and move it back and forth on the slider pins. If it doesnt wanna move or drags and sticks then remove caliper pull the pins and clean the corrosion and lube them. If they are damaged replace them.
There's also another issue that seems to be a cause for the wear and it's the rubber portion of the front brake hoses. Over time, they tend to break down inside and allow the fluid to flow out into the caliper but will not allow the fluid to flow back to the master cylinder reservoir thus keeping pressure on the brakes causing the inside pad to wear more than the outside pad. Also as the rubber breaks down, small pieces will be forced into the caliper causing the pistion to stick. Just something to think about.
Trending Topics
Yeah autozone or advanced didnt have them my local napa had one but they had to get the other one shipped to their store.
