DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Dakota Tech (https://dodgeforum.com/forum/2nd-gen-dakota-tech-67/)
-   -   Help!! Stop running and won't start (https://dodgeforum.com/forum/2nd-gen-dakota-tech/298901-help-stop-running-and-wont-start.html)
slambmx Jul 28, 2011 08:27 AM
Hello,
I have a 2000 Dodge Dakota R/T that stopped running all of sudden and will not restart (just turning over). Any suggestion would help.
1. no codes (checked w/ Superchips tuner, key on and off routine, reset routine)
2. 42 lbs. of fuel pressure in the rails
3. voltage going to injectors
4. voltage to spark plugs
5. changed the cam and crank sensor
6. 02 sensor fuse #24 under the hood not showing any power (not sure why)
7. added gas to throttle body with no response
8. battery full charge
James
moparman_2004 Jul 28, 2011 12:17 PM
im guessing its not making any noises or any thing either
slambmx Jul 28, 2011 01:44 PM
Not making any wierd noises. Did not make any noises when it shut down without warning. I am not if it is the computer. I would think it would fire with spark, fuel and no warning codes. I placed the stock program back and still the same results.
moparman_2004 Jul 28, 2011 02:00 PM
huh idk then you check all your fuses and what the fusable link
slambmx Jul 28, 2011 02:28 PM
Fuse #24 for the 02 Sensors in the engine compartment does not have a source of power, these are the micro fuses. All the others have power. I would think it would send a error code to the computer.
moparman_2004 Jul 28, 2011 04:40 PM
what about the fusable link beyond that have you tryed resetting your ecm
slambmx Jul 28, 2011 07:53 PM
It looks like the alternator is bad. I can't believe that would shut the engine off the engine.
slambmx Jul 28, 2011 09:29 PM
Changed alternator and the same problem. SUCKS!!
© 2026 MH Sub I, LLC dba Internet Brands
