oil pressure
Trending Topics
Thought:
Do the stock oil systems have filter bypasses?
They're a safeguard for when the filter clogs, it lets the fluid bypass the filter. This could cause a higher-than-normal PSI reading because the fluid no longer has to go through the restrictive filter.
Our car had 2 different filter bypasses when we first bought it, and lost 12PSI at idle from the unrestricted flow to the restricted flow, with a Milodon high volume pump. And that's with a low resistance race filter. We're turning about 75PSI at 7000 RPM through the traps, was 85-87 psi with the bypasses. So yes, it makes a difference, it will be exaggerated with a resistive stock style filter.
Mechanical gauges are preferred as they bypass the electrical issue completely.
Yes, in the oil filter. By necessity the bypass has to be at a higher pressure than when the oil flows through the filter media. If it was not, the oil would bypass the filter during normal operation.
So, oil pressure being high could indicate a blocked filter if pressure is measured before the filter and after the pump. If I remember, on the 3.9 the sender is by the distributor. In that case it's reading pressure through the oil galleries, after the filter.
It shouldn't matter.
