Rough ride while driving
my dad had a 1982 club cab double heavy duty springs. Ram VERY rough riding. over size tires. my dad went to a good tire shop, he was told he could change PSI from 70. to 40. it did make it better. the amount you can change will be different, i cant know how much well work for you. not all tires can be lowered in psi. just ask a good tire shop.
It was doing it before i took it. and it does start shaking at a certain speed like 35.
I can fill it in the steering wheel. I am thinking its the rear end or the drive shaft. May be trading truck this weekend hope so. I got the truck back in february and at 91,000 miles on it had to have transmission rebuilt , the service 4wd light is on and I am not happy with the truck anymore....
Trending Topics
As Tbeck1985 mentioned. Check your u-joints. You may want to also do a check on the Motor Mounts. If you have a broken motor mount, it could give you a false sense that it's coming from the rear. Especially if it's under a load of some kind (such as turning to go up a hill or something).
Can't hurt to give them a quick check.
