03 Quad Passenger Windows
Hey guys , on my 03 Quad Cab, my passenger window switches will only work about 10% of the time or less, I can lower the windows fine from the driverside switch.
It seems like when the right front window does not work, neither does the right rear, but when the front works, the rear works, so they are tied in together.
Where do I begin to check?
Hey,
I had this problem. The problem is with the lockout switch on the driver's door. Basically it appears that you cannot unlock the windows so that the passengers can control their windows. Could be a loose connection - I took mine off (the assembly that has on the controls on it on the driver's door) and wiggled connections and put it back on and it has worked ever since. But I have NOT touched the window lock button for fear that it may screw it up again. Let me know if you need pics.
