purolator new filter
Looks like
Looks like a WIX or Mobile 1 oil filter probably same company they just put thier name on it.
I use nothing but Mobile 1 oil filters as of 2008 after I found out how bad Fram was. |
ill bet its made by puralator.
Purolator makes a very good filter, I cut apart several and Purolator, Wix, Motorcraft, and NAPA were great filters and of course Fram was the worst, Fram was the only filter with a plastic surge spring and cardboard end caps on the filter element. The Purolator had a true spring for a surge spring and a silicone antidrainback valve. Motorcraft and Mopar filters are remarkably similar to Purolator,
Originally Posted by 98DAKAZ
(Post 2728184)
Ditto on the stay away from Fram. After doing an oil change about 15 years ago outside in the winter with no garage or carport, I had everything all buttoned up, started the car and looked underneath only to find out that all my new oil was spurting out at the seam between the filter base and the canister. The filter wasn't put together properly. I got it shut off before any damage and that's the last Fram filter I ever bought.
