Stalling Issue!
Stalling Issue!
Hey guys, I'm having a rough time trying to figure out why my 02 dakota 4.7 4x4 is stalling out when the engine is cold. It only does it when I come to a stop, the rpm's drop and sometimes it can catch itself and go back to normal. The strange part is that the idle is rock solid after driving a stopping for a couple miles. I have tried everything I could think of so far. I swapped out the map sensor, tps, iac, and even seafoamed it. I looked through as many of these threads as i could and couldn't find an answer, so if anyone has any ideas I would really appreciate it!
It's odd that it just does it cold. Mine will do it if the throttle body isn't cleaned regularly.
Check for a vacuum leak. Make sure all lines are tight.
Here's one, do you notice it idling better or worse with your foot on the brake? Maybe a bad power booster is causing the a/f to go lean.
With the a/c on, will it still stall?
Ok I'll have to go check all my vacuum lines tomorrow. Yeah I noticed that if I push the break even in park my rpms will drop some. It also does it when I shift gear to reverse and yes it still stalls with the ac on. Thanks for all your help! I'll get back to you about the vacuum lines asap.
Trending Topics
