Dakota Transmission slowing truck
I couldn't find any of this information here so I decided to start a new thread.
I have a 2002 Dakota, 4.7 v8, automatic w/o overdrive.
Symptom:
1) When I put the transmission in Drive or Reverse it would feel like the brakes where binding up. It literately wouldn't move until you started pushing the gas peddle. Even on a hill it wouldn't roll from the gravity!
2) When slowing to a stop, at about 3mph you could take your foot off of the brake peddle & the truck would STOP on its own. I thought brakes again right?
3) On the highway it wouldn't shift into high gear. Engine was going 3000 rpm at 70mph. I assumed that the engine was fighting against the brakes.
Fix:
Checked tranny fluid & it was 1 quart low. I added 1 quart & it fixed it.
I am putting this here because this doesn't make any sense to me. I don't know why having a low fluid level would actually "brake" the vehicle. I was all ready to start pulling the wheels off & taking the brakes apart.
Anyway if your having my Dakota's symptoms I hope this cheap fix works for you too.
Symptom:
Fix:
