Dakota Security- Won't Start
1997 Dodge Dakota Sport. Here's what happened. I had a good running truck. Someone broke into it wrecked the steering column. Then someone smacked into the entire drivers side. Replaced the column, battery was dead. Replaced battery, truck still won't start. I have the regular black keys and two button fob. OEM security. I turn the key I here a light thump on the drivers side under hood, then nothing. Security light stays on a few seconds then flashes then off. Set off the alarm by opening door and disarmed it with fob. Still nothing. Can't disarm with door or ignition.
No codes overhead odometer blank, dash odometer blank, no radio. Ignition will ding if the door is open with key in. Alarm sounds. Radio will show time if I push teh button. Outside and interior lights work. Basically none of the features, that come on when truck is on, work. I turn the key just that light thump then the security light on dash..
