97 dakota, tire and wheel help plz!
Old 07-19-2015, 10:35 PM
Muffinman36's Avatar
Muffinman36
Muffinman36 is offline
Default 97 dakota, tire and wheel help plz!
So I recently purchased the Adrenaline XDC Series II 3" Suspension Lift System (1997-2004 Dodge Dakota 4x4) for my 97 v8 standard Dakota. Once I get the lift installed I'm going to pull the trigger on new tires and wheels. I'm trying to run the biggest possible tires without ANY rubbing and I seem to be getting mixed answers from everyone I talk to.
What is the best size tire/wheel combo for Dakota with a 3 inch suspension lift??
Thanks for the input!
Old 07-20-2015, 09:14 AM
jkeaton is offline
Dodge Forum Administrator
Old 07-03-2016, 02:14 PM
barrysuperhawk's Avatar
barrysuperhawk
barrysuperhawk is offline
I ran 325-60r15's on my '99 with no lift and only minimal rub on the frame rail at full lock... yes 325's.
Old 07-10-2019, 10:43 AM
frankiedon53's Avatar
frankiedon53
frankiedon53 is offline
Hi Friar Tuck, I had similar problems with my 2001 dodge ram van, so I replaced all of the relays because of the age and the relays are not very expensive.Especially the A.S.D. relay ; it controls the fuel injectors, coil. etc and shuts down the fuel in the event of an accident so as to prevent a fire.Even if it is clicking I would replace it.Switch the relays around temporarily and see if it helps. They are interchangeable.I also had an intermittent no-crank and found that the range-sensor was faulty; it tells the P.C.M. what position the shift is in and causes a no-crank problem if it is worn inside. I replaced the starter relay, A.S.D. relay and fuel pump relay. Hope you get rolling again soon. Frank
Old 07-10-2019, 11:30 AM
jkeaton is offline
What in the world are you talking about?
Old 07-11-2019, 03:34 PM
98DAKAZ's Avatar
98DAKAZ
98DAKAZ is offline
I think this guy is lost his post says he’s from Barbados.
Old 07-12-2019, 06:43 AM
frankiedon53
Hi Frank O'Donnell here: Did I mess-up some how? I am confused may be I answered the incorrect post. Please direct me. I haven't been on the forum for a long time, and I wanted to help out that person with the dodge ram no-start. Thank you Frank
Old 07-12-2019, 07:21 AM
HeyYou is online now
Received 3,177 Likes on 2,930 Posts
This isn't even close to the thread you are talking about. This is in the dakota section, and the guy is talking about lift kits. I have no idea how you managed that one. Do you have multiple tabs open? Maybe you just responded on the wrong one?
Old 07-11-2020, 01:32 AM
Romul_UA's Avatar
Romul_UA
Romul_UA is offline
+ 1 in EuroAsia
Old 07-11-2020, 01:35 AM
Romul_UA's Avatar
Romul_UA
Romul_UA is offline
Originally Posted by Romul_UA
+ 1 in EuroAsia
I'm sorry - wrong thread
Quick Reply: 97 dakota, tire and wheel help plz!
