Chipped keys
Is it possible to program your own chipped key? I have only one from hte prev owner and not very comfy with that.
I read there are some cars you can do it with. |
I googled this
But other searches came up with a resounding NO YOU CAN'T |
Originally Posted by John3475
(Post 3305497)
My local hardware store (Ace) does it.
Key
Apparently the guy's method is to remove the chip and stick it near the key cylinder on the column. Sounds interesting. Maybe just stick the whole key to the column.
(Post 3305619)
Even if you do stick the transponder somewhere, it will still eventually die.
The general dealer charge is usually .5 labor time to program no matter how many keys. Don't buy the dealer keys...too much $$ for just a SKIM key. |
Keys
Ok. So I get the keys on ebay and get the code from dealer,go to locksmith and he plugs in his gizmo and there is no sign of life from the Obd port. That sounds odd, maybe someone disabled it?
(Post 3306061)
Got the key
Had PEP boys check my OBD codes (none) just to verify the port was working and finally got the key made, the locksmith's 1st gizmo wouldn't work so he pulls out a second one and that one doesn't work in my truck either, he gets a third, but can't find the power cord for it! He goes back in the shop and brings out a 4th device that he guarantees will work and it did. He said it uses tokens or something, Final cost was 40.00 for locksmith and two keys on ebay for 17 bucks.
