1998 Dakota won't start
98 Dakota 3.9L w/auto tranny. After replacing tranny, was able to drive it about 3 miles and it acted like it had timing and or ignition issues, ran really rough and died. Threw code for crankshaft position sensor, replaced it and nothing happened, would turn over but wouldn't start. Replaced the sensor a second time (thinking the new one might be faulty) and the CPS sensor went away and the camshaft position sensor circuit bank 1 sensor 1 was present. After replacing said camshaft position sensor under the newly replaced distributor cap and rotor, the p0340 code never went away. The truck will turn over but will not start. Verified spark and could smell fuel from the carb but no fire. NOTE: After replacing tranny I also replaced MAP sensor, TPS sensor, dist. cap and rotor, plugs, wires and boots, coil pack and battery terminal connectors. Thinking the ECM might be bad but don't know how to test this. Any ideas?
Are you sure you got the plug wires back on in the right order? I would check that first then check each part you replaced making sure the connections are clean and tight.
P0340 - no cam signal at PCM. Without that there is no fuel sync. The cam and crank position sensors use the same 5 volt supply and sensor ground. Check the harness carefully for any damage especially near the exhaust manifold (CKP).
Why did you replace all those sensors? Were there other faults? Suggestion, use ONLY OEM sensors. There are many in this forum that have had problems with aftermarket sensors. |
Originally Posted by Chris Cox
(Post 3308549)
Originally Posted by Robertwav1
(Post 3308741)
A little confused on the "camshaft position sensor circuit bank1 sensor1 was present"? The only sensors I know on that engine that refer to bank1 sensor1 would be 02 sensors?
(Post 3308741)
Also....carburetor?
Sounds like a pinched wire to me
Yes, replaced them one for one.
Yes, fuel injected. My mistake.
