hello there guys i need some info on if i could switch my 00 dodge dakota 4.7 engine with a 45rfe tranny from 2wd to 4wd and if that's so bout how much do you think it would cost and get info on wat i would have to replace to make it 4wd if possible
The front differential is supported by the motor mounts.
You'd also have to "flip" the rear axle.
I agree with Magnethead. You'd need a complete 2000 4x4 donor truck to do this. Earlier years won't have the engine mounts/suspension parts you need. Later years have an electronic t-case.
