Air Conditioner on when not supposed to be
I have a 2000 SLT, 4.7, 4x4, automatic.
The A/C works well. However, it runs when it is in the 3rd position going clockwise. Or, the 4th if you include the off position. I think it may also run in other positions like the defrost position. I can hear the compressor turn on and off, the engine idle changes etc....
I've pulled the fuse to the A/C and the engine runs smoother.
The heater also blows barely warm when idling (at full engine temp) and blows warm when running. I think this is a separate issue based on the reading I've done. But, thought I would throw it in the mix in case I'm wrong.
Any help on how to fix this would be appreciated.
I have had the same problems with my 2000 3.9L truck when it comes to low heat output during winter. AC runs great in the summer and I always heard the compressor kicking on with the defroster setting. I found if you set the dial to defrost/floor, the compressor runs very little or does not kick on like on straight defrost. I tried back flushing the heater core and that really did not help much, so this fall I did the flush method. I poured a bottle of prestone flush and run the truck for 4 days and then took it to Sears for a coolant exchange where the coolant is sucked out using vacuum pressure while the engine is running. This method did help increase my heat temperature on cold mornings. It usually took 4 to 5 miles of driving before my guage would finally move above cold. Now it starts to move after 2-1/2 miles. Always had the problem of long warm up time, but once the gauge moves up, the single cab will toast you.
