Found a leak on the front axle just trying to figure out what it is that's leaking. I have a picture can anyone tell me what part of the truck this is?
Clean the fitting first. Some seepage happens after a while.
When do you hear the whirring? If all the time, even when not moving, I'd suspect a bad p/s pump. More likely you hear it only when moving and it's probably a wheel bearing.
It's really bad started leaking all the time now even while moving as before used to be noticeable only while stationary. The noise is only when moving anything over 30mph.
