DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Dakota Tech (https://dodgeforum.com/forum/2nd-gen-dakota-tech-67/)
-   -   2001 Odd Dakota question (https://dodgeforum.com/forum/2nd-gen-dakota-tech/418157-2001-odd-dakota-question.html)
Pure Logic 09-22-2018 03:26 PM
I have a near mint 2001 Dakota, and what it needs no one wants to make the repair.
The right front frame has a factory welded bracket that supports the A arm and the shock, and it is half rusted off. I don't think I can buy it, and not sure if my only option it to cut one off at a recycling yard. Any ideas?
magnethead 09-22-2018 03:52 PM
Yes, that is likely your only option. The upper control arm mounts to the frame though, I don't think it interacts with the top shock mount at all.
Pure Logic 09-22-2018 04:41 PM
Thanks magnethead
It looks to me like the long bolt of the upper A arm goes through this bracket along with the upper shock bolt.
But I'll try to get Mama to post a picture, which I should have done to begin with.
magnethead 09-22-2018 07:48 PM
Both upper A arm bolts go in from the top and thread into block nuts between the UCA bracket and the top of the frame rail itself.
Pure Logic 09-23-2018 01:17 PM
Pure Logic 09-23-2018 01:21 PM
What a waste. There's really nothing I can do with this except part it out.
HeyYou 09-23-2018 02:54 PM
Find another one in the junk yard, cut what you need off that one, weld it onto yours. The rest of the truck looks to be in REALLY good condition......
magnethead 09-23-2018 06:19 PM
Yea you're pretty SOL there. All you can really do is cut and graft off a donor frame.... Which I bet is going to be hard to find a good donor one....
HeyYou 09-23-2018 08:34 PM
Wonder if a fab shop would make one up.......
magnethead 09-23-2018 09:28 PM
Having worked at one....probably not. Too many insurance liabilities.
