1997 5.2 Dakota hard to start in 70> weather, runs fine otherwise
So i have a 1997 5.2 RWD Dakota, 334k miles, most reliable vehicle i have ever owned, until now. I have a strange problem that i cannot find a straight solution for. The truck has always had trouble starting when the temperature gets below 70 degrees F, but usually I would crank it 2-3 times and get a start. Only last year, when working in Oklahoma during winter, I noticed that if i put the key into ACC mode, and let the truck sit, the battery and fuel gauge would eventually ping to their normal positions, only then, it would start every time, with only one crank lasting one second. I have noticed that if the key is put into ACC and the gauges dont move, the truck WILL NOT start. Once the gauges move to normal position, it starts every time, no problems.
Since i noticed this phenomenon, i click the key to ACC, wait, and the truck will fire up. Sometimes when the temp was 40 and below, it would take 5+ minutes of letting it sit in ACC, sometimes clicking the key back and forth helps, sometimes not. Ive done fuel pressure tests(good), and can hear the pump whirring the entire time until the gauges ping(then it stops).
My problem now, is that the truck is not even getting to the point of the gauges moving in 65/below temps. My truck hasnt been wanting to start lately in this weather, and i had to leave it at work recently for a few days until the temp rose to 70F, and it fired up no problem. Another thing that stays on now is the yellow "Security" light, while its waiting for the battery/fuel gauge to move
Any ideas on where to troubleshoot?
