Transmission stuff
So i traded 2wd Ford for a 2000 dakota 4 door 4.7 with 45rfe. Transmisson was said to be problematic. Came with spare rfe and transfer case. Seems it was in limp mode it wanted to go with hardly any power surgering. So i took the entire valvebody and the elcectronic part from the said working transmission, cleared the main limp codes and od error..
When driving it sometimes not wanting to shift into 3rd and 4th but 1 2 and R are strong.. feels like a slip anyeays its o ly got 6 qts of fluid gotta add more but beyound that any ideas before i swap the entire transmissions. I am planning on full rebuild down the road just for now trying to try and just get it going to drive dependable. |
Also; is it normal for code reader not able to clear the codes on these years? I have a cheap little reader the 20.00 one from tractor supply - that refuses to reset the codes; only way i can clear them is disconnecting the battery for a while.
Is it just a cheap reader or is that typical of transmission codes on these trucks? Sorry for the dumb questions if it is; my previous dak was a 44 w/ 318 so it didn't have issues like this. |
Ok today filled fluid does not even try and shift now just goes out of 2nd and nothing.. im going to clear it using the battery disconnect maybe its in some limp mode since 3rd and 4th were on the mil still..
What codes do you have? |
Originally Posted by Physkomere
(Post 3425226)
What codes do you have? P0734 and p0733 before that i had 2 others two but i swapped the valve body with the electronic part as it was not wanting to drive at all. When those codes fpr 3rd and 4th hit it felt like it was slipping when they came on and since the mil lit it wont try so now i have fluid level up im resetting to see what it does. |
Have you tried testing your output speed sensor? I’ve heard that can mess these up. |
https://cimg9.ibsrv.net/gimg/dodgefo...4202742922.jpg
So with full fluid it tried shifting to 3rd but was slipping really bad not going in gear produced P0733 for 3rd gear never made it to 4th.. R 1st 2nd is good but it shifts hard i to drive though a litle harder than i feel it ahould. a LL WORKING gears seem strong. I have not tried speed sensor just the main component Im considering swapping the other trans in but the tag only says RFE not 45RFE is this still compatible? The thing looks identical other than the tag. The pic listed is the transmission that supposedly came from a working vehicle. Not sure what kind. Supposedly works |
Can’t you compare the identification numbers with yours? If not I’ll go look under my truck in the morning. Too dark and cold currently for me. |
Which number ? I can look on mine i dont know nothing about these years or how to match them they look identical i have a feelimg its the 3rd and 4th clutches when i dropped the pan i wiped alot of what looked like thick old black sludge. The one that is the spare i took the sensor from pan looks clean.
The number that ends in AD. I don’t know much about them either but I figured I’d try to help since you’re going through something similar to me. |
