3.9 4X4 Dakota Trans 42RE
Old 01-21-2019, 02:09 AM
Cameron Crosby's Avatar
Cameron Crosby
Cameron Crosby is offline
Default 3.9 4X4 Dakota Trans 42RE
What transmissions will fit in my 2001 3.9 V6 4X4 Dakota? I know it has a 42RE in it right now but would a 46RE fit and match up?
Old 01-21-2019, 10:36 AM
magnethead's Avatar
magnethead
magnethead is offline
On a 4x2, all 3 transmissions (42/44/46RE) are generally interchangeable as long as you use the right mount on the tailshaft and the matching length driveshaft. On a 4x4, I don't know as much about the mating bolt pattern and intermediate shaft spline count. I would like to say that they are interchangable, but you'd need the matching set of driveshafts if that were still the case. I know the 42 and 46 are different lengths. I'm not sure where the 44 falls.
Old 01-21-2019, 02:35 PM
Skreelink's Avatar
Skreelink
Skreelink is offline
The 44RE is in the same transmission case as the 42RE, just an extra friction and steel per clutch pack and dropped behind the 318. The 46RE is longer, so they would need a change of driveshafts.
Quick Reply: 3.9 4X4 Dakota Trans 42RE
