DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   2nd Gen Dakota Tech (https://dodgeforum.com/forum/2nd-gen-dakota-tech-67/)
-   -   01 Dakota Serpentine belt comes off - I'm Stuck (https://dodgeforum.com/forum/2nd-gen-dakota-tech/430987-01-dakota-serpentine-belt-comes-off-im-stuck.html)
ru4him2 Jun 4, 2020 03:35 PM
The serpentine belt kept crawling off the A/C pulley. I replaced the tensioner pulley but it didn't help. I put a shorter belt on to bypass the A/C pulley and it still crawls off power steering pulley and shreds the edge of the belt. I pulled the power steering pulley in and out by hand and saw there is a little play. Is that the problem and will it take a new power steering unit to fix it?
Vimes Jun 4, 2020 04:56 PM
If the pulley moves on the shaft, then the shaft is moving inside the pump. Yes, your pump is toast. You could possibly rebuild it, but it would be cheaper to get a new one, emphasis on new. Part store "rebuilds" are someone else's worn out pump that's been dipped in cleaner that's now illegal in the US, and... that's it. You'd only come out ahead if the pump you get is one that someone else replaced by mistake. If a new one is no longer available, try for a Mopar or NAPA gold rebuild. At least they're actually rebuilt. You can also call around to your local hydraulic shops and see if anyone local to you can rebuild it.
HeyYou Jun 4, 2020 05:24 PM
When mine did that, the power steering pump pulley cam off in my hand, along with the shaft it was mounted on, when I took the belt off.......
© 2026 MH Sub I, LLC dba Internet Brands
