P0270 code won't clear
Last year I came up with code Po270 on my 99 V6 Dakota and replaced the rear speed sensor. Simple enough.
I just had the same code come up again, however after replacing the sensor again and clearing the code, after a minute the code came right back. The vehicle runs fine with the exception of taking a few more RPMs to shift gears. Is there anything else that is usually associated with this error code? Thanks. |
RE: P0270 code won't clear
Correction P0720.
The code reads that the output shaft speed isn't within spec of vehicle speed. Sounds like there is a sensor on the tranny output?
| All times are GMT -4. The time now is 12:22 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
