Installing headers on 99 Dakota 4x4
RE: Installing headers on 99 Dakota 4x4
it's easy, a little time consuming but easy... pull off the old manifolds, remove all of the studs on the head, then re-install the new manifold with the supplied bolts. I suggest you stud the end bolts on each head as they may go into a waterjacket in the head.
use a 2 nut method on each stud that your removing... tighten the 2 nuts together and remove the inner nut. stud should come right out. for extra peace of mind, soak the studs with liquid wrench or pb blaster 1st before removing them.
