hmm...good or bad idea?
Ok here it is again. For the life of me I cannot find a O2 sensor for my 2000 4.7l. so i used the one that its supposed to be and notched out the side of the plug to fit the end thats attached to the truck. I know its not water tight but neither is the plug as it is. do you guys think this is a good or bad idea. Its all i can do.i was desperate. Thanks for your input.
RE: hmm...good or bad idea?
Well if you're not getting any CELs you might try globbing it up with a non-conductive grease and wrapping it in tape to keep corrosion down and water out.
For future reference, just cut the plug off the OEM one and get a universal fit sensor then connect the two.
Trending Topics
sorry man Ur post just makes absolutely no since your first post says that you cant splice the OEM part, no room for a splice, which wouldn't call for one any way, then your second one says that the part works fine...
next time don't post if you don't want us to try to help...
