P0132 (M) 1/1 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained abo
P0132 (M) 1/1 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal operating range.
I'm assuming that I need to replace my first O2 sensor, from the code I got, But I don't know where the O2 sensors are in my truck, It's 2001 quad cab 5.9L (not R/T)
Follow the exhaust pipes from the exhaust manifold down to the catalytic converter. It's easy to see from under the truck. It's in front of the cat, screwed into the exhaust pipe. If you have 2 cats one on each side you need to replace both O2's. I'm not sure if the 5.9 has 1 or 2.
the 5.9s have 4 i just went through replacing them and my cats the back 2 sensors are easy yhe top 2 are a real pain in the a$$ and it cost me about 60 a peice for each sensor and that was for the universals if you have any questions about it I just did this a week ago
