2000 Dodge Dakota wiring for radio
Old 09-25-2012, 11:53 AM
crash67's Avatar
crash67
crash67 is offline
Cool 2000 Dodge Dakota wiring for radio
Good day. I own a 2000 Dodge Dakota 4x4. Great truck and got it at an unbelievable price. It had the factory radio re-installed. I installed my own cd player, but now the instrument panel dimmer lights do not work. Does any one have a wiring harness diagram for this truck. Any help would be appreciated.
Thanks
Crash67
Old 09-26-2012, 11:57 PM
master tech's Avatar
master tech
master tech is offline
Site Moderator & Tech
Dodge Forum Moderator
Welcome to DF
I will move your post to the 2nd Gen Dakota section.
Old 09-27-2012, 12:14 AM
01SilverCC's Avatar
01SilverCC
01SilverCC is offline
You need to check the black/yellow and orange wires in the factory radio harness. Be sure they are not touching metal and shorting out behind the radio opening. The black/yellow is the parking light/dash light illumination wire, and the orange is the dimmer circuit. Tape up or cap off/insulate those wires first and then check the fuse panel, you probably popped the dash light fuse. I do not know which one it is exactly, but the fuse box cover has a label on the inside of it and it should be a 5 amp fuse.
Jimmy
Old 09-27-2012, 11:07 AM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
For the entire service manual, including the wiring diagrams, go here:
https://dodgeforum.com/forum/2nd-gen...-download.html
Quick Reply: 2000 Dodge Dakota wiring for radio
