45rfe transmission question!!!
i have a couple codes on my 2000 4x4 4.7.... Po733 and p 1781.... I took off the pan and there were no broken peices or any shavings on the magnet.... the question is, will a transgo kit fix my problems of no third gear and A/T Overdrive Pressure Switch Circuit Malfunction??? any help is apprecciated!
No. Unfortunately, transmissions aren't really my strong point. But the codes kind of give you a direction to go. Any good transmission shop should be able to diagnose it pretty easily. Sorry I can't be of any real help.
Hi New,
Try this thread from the Durango forum. He had similar codes:
https://dodgeforum.com/forum/1st-gen...and-p1781.html
